u4.81.44 Opérateur COMBINAISON_FERRAILLAGE#
mult_elas = COMBINAISON_FERRAILLAGE(
    ◆ reuse = <objet de RESULTAT>,
    ◆ CARA_ELEM = cara_elem,
    ◆ RESULTAT = mult_elas,
    ◆ COMBINAISON = _F(
         ◆ TYPE = / "ELS_CARACTERISTIQUE",
                  / "ELS_QUASIPERMANENT",
                  / "ELU_ACCIDENTEL",
                  / "ELU_FONDAMENTAL",
         ◆ / NOM_CAS = list[text],
           / NUME_ORDRE = list[int],
    ◇ CODIFICATION = / "BAEL91",
                     / "EC2" (par défaut),
    ◇ METHODE_2D = / "CAPRA-MAURY" (par défaut),
                   / "SANDWICH",
    ◇ PAS_THETA = float (défaut: 5),
    ◇ PAS_EPAI = float (défaut: 0.01),
    ◇ PAS_SIGM = float (défaut: 0.1),
    ◇ COND_109 = / "NON",
                 / "OUI" (par défaut),
    ◆ UNITE_CONTRAINTE = / "MPa",
                         / "Pa",
    # Si: equal_to("CODIFICATION", 'EC2')
        ◆ AFFE = _F(
               / GROUP_MA = list[grma],
             ◆ TYPE_STRUCTURE = / "1D",
                                / "2D",
             ◇ FERR_SYME = / "NON" (par défaut),
                           / "OUI",
             ◇ SEUIL_SYME = float,
             ◇ FERR_COMP = / "NON" (par défaut),
                           / "OUI",
             ◇ EPURE_CISA = / "NON" (par défaut),
                            / "OUI",
             ◇ FERR_MIN = / "EC2",
                          / "VALE_MIN",
             # Si: equal_to("FERR_MIN", 'VALE_MIN')
                 ◆ RHO_LONGI_MIN = float,
                 ◆ RHO_TRNSV_MIN = float,
             # Si: equal_to("TYPE_STRUCTURE", '2D')
                 ◆ C_INF = float,
                 ◆ C_SUP = float,
             # Si: equal_to("TYPE_STRUCTURE", '1D')
                 ◆ C_INF_Y = float,
                 ◆ C_SUP_Y = float,
                 ◆ C_INF_Z = float,
                 ◆ C_SUP_Z = float,
             ◇ ALPHA_E = float,
             ◇ RHO_ACIER = float (défaut: -1),
             ◇ FYK = float,
             ◇ EYS = float,
             ◇ TYPE_DIAGRAMME = / "B1",
                                / "B2" (par défaut),
             ◇ GAMMA_S_FOND = float,
             ◇ GAMMA_S_ACCI = float,
             ◇ FCK = float,
             ◇ GAMMA_C_FOND = float,
             ◇ GAMMA_C_ACCI = float,
             ◇ ALPHA_CC = float (défaut: 1.0),
             ◇ SIGS_ELS = float,
                 ◇ SIGC_INF_ELS = float,
                 ◇ SIGC_SUP_ELS = float,
                 ◇ SIGC_INF_Y_ELS = float,
                 ◇ SIGC_SUP_Y_ELS = float,
                 ◇ SIGC_INF_Z_ELS = float,
                 ◇ SIGC_SUP_Z_ELS = float,
                 ◇ WMAX_INF = float,
                 ◇ WMAX_SUP = float,
                 ◇ WMAX_INF_Y = float,
                 ◇ WMAX_SUP_Y = float,
                 ◇ WMAX_INF_Z = float,
                 ◇ WMAX_SUP_Z = float,
             ◇ SIGC_ELS_QP = float,
             ◇ KT = float,
             ◇ PHI_INF_X = float,
             ◇ PHI_SUP_X = float,
             ◇ PHI_INF_Y = float,
             ◇ PHI_SUP_Y = float,
             ◇ PHI_INF_Z = float,
             ◇ PHI_SUP_Z = float,
             ◇ UTIL_COMPR = / "NON" (par défaut),
                            / "OUI",
             ◇ CLASSE_ACIER = / "A",
                              / "B" (par défaut),
                              / "C",
             # Si: greater_than("RHO_ACIER", 0)
                 ◇ ALPHA_REINF = float (défaut: 1),
                 ◇ ALPHA_SHEAR = float (défaut: 1),
                 ◇ ALPHA_STIRRUPS = float (défaut: 1),
                 ◇ RHO_CRIT = float (défaut: 150),
                 ◇ DNSTRA_CRIT = float (défaut: 0.006),
                 ◇ L_CRIT = float (défaut: 1),
    # Si: equal_to("CODIFICATION", 'BAEL91')
        ◆ AFFE = _F(
                                / "2D",
                           / "OUI",
                           / "OUI",
                            / "OUI",
             ◇ FERR_MIN = / "BAEL91",
                          / "VALE_MIN",
                 ◆ C_INF = float,
                 ◆ C_SUP = float,
                 ◆ C_INF_Y = float,
                 ◆ C_SUP_Y = float,
                 ◆ C_INF_Z = float,
                 ◆ C_SUP_Z = float,
             ◇ N = float,
             ◇ FE = float,
             ◇ EYS = float,
                                / "B2",
             ◇ FCJ = float,
             ◇ ALPHA_CC = float (défaut: 0.85),
             ◇ SIGS_ELS = float,
                 ◇ WMAX_INF = float,
                 ◇ WMAX_SUP = float,
             ◇ KT = float,
Opérande RESULTAT et CARA_ELEM#
♦ RESULTAT = resu
Nom d’un concept résultat de type mult_elas. Il est nécessairement ré-entrant.
♦ CARA_ELEM = carac
Il est nécessaire de renseigner les caractéristiques élémentaires par le mot-clef CARA_ELEM pour tous les résultats statiques & dynamiques. Ce changement est induit par l’intégration de POST_COMBINAISON(U4.81.45) qui génère un résultat ELAS_MULT sans associé de CARA_ELEM.
Opérande CODIFICATION#
♦ CODIFICATION = /‘EC2’, [DEFAUT]
/'BAEL91',
C’est la codification à utiliser pour les vérifications.: Eurocode 2 (EC2) ou BAEL91.
Opérande COMBINAISON#
♦ COMBINAISON = _F(♦ TYPE = / “ELS_QUASIPERMANENT”,
/”ELS_CARACTERISTIQUE”,
/”ELU_FONDAMENTAL”,
/”ELU_ACCIDENTEL”,
♦ /NOM_CAS = l_nomcas
/NUME_ORDRE = l_numeordre,)
Avec cette opérateur répétable on fournit à la commande la liste des cas (résultats de la mult_elas) sur lesquels réaliser le dimensionnementqui correspondent aux vérifications d’état limite de service (la combinaison caractéristique est la seule disponible pour le moment) et ultimes (fondamentaux, accidentelles).
Le choix entre ELU_FONDAMENTALet ELU_ACCIDENTEL permet de choisir la valeur des coefficients de sécurité GAMMA(voir opérande AFFE, § 3.4 ).
Mot-clé TYPE#
/”ELU_FONDAMENTAL”,
/”ELU_ACCIDENTEL”,
Avec ce mot-clé, on choisit le type de vérification à associer à la liste de cas. Pour l’instant les options disponibles sont les états limites ultimes fondamentaux ou accidentels et les états limites de service caractéristiques et quasi-permanents tels que définis par les Eurocodes.
Mot-clés NUME_ORDRE et NOM_CAS#
Ici est fournie la liste des cas associée à la vérification renseignée dans TYPE, soit comme liste desnuméro d’ordre des cas soit comme liste des noms des cas (étiquette associée à chaque résultatde la mult_elas).
Remarque
Ici le numéro d’ordre n’indique pas un instant de calcul ou une fréquence comme pour le structures de données résultatmais un numéro de cas (un des résultatscontenus par la multi_elas).
Opérande AFFE#
Une grande partie des mot-clés renseignéesici sont les mêmes que pour la commande CALC_FERRAILLAGE. Une différence avec les mot-clés de CALC_FERRAILLAGE consiste dans le choix des coefficients de sécurité:
◊ GAMMA_S_FOND= gs, [R]
◊ GAMMA_S_ACCI= gs, [R]
◊ GAMMA_C_FOND= gc, [R]
◊ GAMMA_C_ACCI = gc, [R]
On choisira les valeurs renseignées sous GAMMA_S_FOND et GAMMA_C_FOND pour alimenter CALC_FERRAILLAGE si l’utilisateur a choisi l’option ELU_FONDAMENTAL de l’opérande COMBINAISON (§ 3.3 ) pour un certain cas de charge. Pour ELU_ACCIDENTEL, les valeurs de GAMMA_S_ACCI et GAMMA_C_ACCI seront sélectionnées.
Composition du champ produit#
Le résultat de chaque cas de nom NOM_CAS est enrichi par un nouveau champ (nommé “FERRAILLAGE” dans la structure de données) dont les composantes sont:
Si TYPE_STRUCTURE = ‘2D’ :
  • une densité de ferraillage longitudinal dans le sens \(X\) de l’élément pour la face inférieure de l’élément (\(\mathrm{DNSXI}\) ) ;
  • l’équivalent pour la face supérieure (\(\mathrm{DNSXS}\) ) ;
  • une densité de ferraillage longitudinal dans le sens \(Y\) de l’élément pour la face inférieure de l’élément (\(\mathrm{DNSYI}\) ) ;
  • l’équivalent pour la face supérieure (\(\mathrm{DNSYS}\) ) ;
  • la densité de ferraillage transversal dans le sens \(X\) de l’élément (\(\mathit{DNSXT}\) ) ;
  • l’équivalent dans le sens \(Y\) de l’élément (\(\mathit{DNSYT}\) ) ;
  • la densité volumique totale d’acier (\(\mathit{DNSVOL}\) );
  • un indicateur de complexité de mise en œuvre du ferraillage (\(\mathit{CONSTRUC}\) ).
Si TYPE_STRUCTURE = ‘1D’ :
  • une densité de ferraillage longitudinal suivant l’axe \(Y\) de la section, et selon le sens positif de l’axe (face supérieure suivant la hauteur h) (\(\mathit{AYS}\) ) ;
  • une densité de ferraillage longitudinal suivant l’axe \(Y\) de la section, et selon le sens négatif de l’axe (face inférieure suivant la hauteur h) (\(\mathit{AYI}\) ) ;
  • une densité de ferraillage longitudinal suivant l’axede la section, et selon le sens positif de l’axe (face supérieure suivant la largeur b) (\(\mathit{AZS}\) ) ;
  • une densité de ferraillage longitudinal suivant l’axe \(Z\) de la section, et selon le sens négatif de l’axe (face inférieure suivant la largeur b)(\(\mathit{AZI}\) ) ;
  • une densité de ferraillage transversal (\(\mathit{AST}\) ) ;
  • une densité de ferraillage longitudinal total (\(\mathit{ATOT}\) ) ;
  • un indicateur de complexité de mise en œuvre du ferraillage(\(\mathit{CONSTRUC}\) ).
Le champ de ferraillage est calculé pour le seul instant existant pour chaque cas. Un des buts principaux de la commande COMBINAISON_FERRAILLAGE est de calculer, pour chaque type d’armature (longitudinale, transversale…), la combinaison dimensionnante, c’est à dire celle qui maximise le type d’armature considérée.
Ainsi, l’algorithme de la commande COMBINAISON_FERRAILLAGE appelle la commande CALC_FERRAILLAGE pour chaque cas (numéro d’ordre de mult_elas) en choisissant le type de vérification renseignée par TYPE_COMB. Ensuite, les densités d’armature (pour chaque type d’armature) sont comparées entre elles, celle qui donne lieu à l’armature la plus importante est la combinaison dimensionnante. Cette comparaison est faite à chaque appel de la COMBINAISON_FERRAILLAGE, donc sur chaque nœud des groupes de mailles sélectionnés.
Il y aura donc autant de combinaisons dimensionnantes que de types d’armatures.
On crée dans la structure donnée multi_elas deux nouveaux cas :
  • COMB_DIME_ACIER → Sous ce nom de cas sont renseignés les armatures maximales pour chaque élément fini et type d’armature
  • COMB_DIME_ORDRE → Sous ce nom de cas sont renseignés les numéro d’ordre des cas qui fournissent les armatures maximales (cas dimensionnants) pour chaque élément fini et type d’armature.
Erreurs et alarmes#
Erreurs causées par une incohérence des paramètres d’entrée#
Une vérification de la cohérence des paramètres d’entrée est réalisée au début de l’exécution de la commande COMBINAISON_FERRAILLAGE. Le calcul peut être stoppé par une erreur fatale dans les cas suivants:
  • si aucune occurrencede l’opérande COMBINAISON ou AFFE n’est renseignée.
  • dans le cas BAEL91à l’ELU FONDAMENTAL : si les mots-clé GAMMA_S_FOND,GAMMA_C_FOND,FEou FCJ, ne sont pas renseignés;
  • dans le cas BAEL91à l’ELU ACCIDENTEL : si les mots-clé GAMMA_S_ACCI,GAMMA_C_ACCI,FEou FCJ, ne sont pas renseignés;
  • dans le cas BAEL91à l’ELS: si les mots-clé N, SIGS_ELSou SIGC_ELSne sont pas renseignés;
  • dans le cas BAELà l’ELS_QP: si les mots-clé ALPHA_E, FYK, FCK,SIGC_ELS_QP, WMAX_INF/SUP(_Y/Z),KT, PHI_X/Y/Z_INF/SUP ne sont pas renseignés;
  • dans le cas EC2à l’ELUFONDAMENTAL : si les mots-clé GAMMA_S_FOND,GAMMA_C_FOND,FYKou FCK, ne sont pas renseignés;
  • dans le cas EC2à l’ELU ACCIDENTEL : si les mots-clé GAMMA_S_ACCI,GAMMA_C_ACCI,FYKou FCK, ne sont pas renseignés;
  • dans le cas EC2à l’ELS: si les mots-clé ALPHA_E, SIGS_ELS,SIGC_INF/SUP(_Y/Z)_ELSouFCKne sont pas renseignés;
  • dans le cas EC2à l’ELS_QP: si les mots-clé ALPHA_E, FYK, FCK,SIGC_ELS_QP, WMAX_INF/SUP(_Y/Z),KT, PHI_X/Y/Z_INF/SUP ne sont pas renseignés;
  • pour tous les cas: si la valeur de l’enrobage est supérieure à l’épaisseur/hauteur/largeur de l’élément de structure.
Ainsi que les cas particuliers suivants:
  • si FERR_MIN = ‘VALE_MIN’ et que les mots-clés RHO_LONGI_MIN et RHO_TRSNV_MIN ne sont pas renseignés.
  • si FERR_SYME = ‘OUI’ et que le mot-clé SEUIL_SYME n’est pas renseigné.
Alarmes émises lors du calcul des aciers#
Le calcul des aciers de flexion peut émettre une ou plusieurs alarmes dans les cas suivants :
  • si l’élément ‘1D’ ou au moins une facette de l’élément ‘2D’ est en pivot B trop comprimé, avec FERR_COMP = ‘NON’ : dans ce cas la densité de ferraillage est fixée à -1 pour l’élément (et le calcul sur les autres facettes de l’élément ‘2D’ est ignoré)
  • si l’élément ‘1D’ ou au moins une facette de l’élément ‘2D’ est en pivot C trop comprimé avec FERR_COMP = ‘NON’ : dans ce cas la densité de ferraillage est fixée à -1 pour l’élément (et le calcul sur les autres facettes de l’élément ‘2D’ est ignoré)
  • si FERR_SYME = ‘OUI’ et que l’algorithme ne réussit pas à déterminer un ferraillage symétrique pour l’élément ‘1D’ (ou pour au moins une facette de l’élément ‘2D’) qui respecte le seuil de tolérance rensigné au niveau du mot-clé SEUIL_SYME : dans ce cas la densité de ferraillage est fixée à -1 pour l’élément
  • si l’élément ‘1D’ est soumis à une flexion déviée, et que l’algorithme itératif de dimensionnement par vérification de l’inéquation de Bresler ne parvient pas à converger: dans ce cas la densité de ferraillage est fixée à -1 pour l’élément
  • si TYPE_COMB = ‘ELS_QP’ et que l’algorithme itératif de dimensionnement basé sur la vérification de l’inéquation de l’ouverture des fissures ne parvient pas à converger: dans ce cas la densité de ferraillage est fixée à -1 pour l’élément
Exemples d’utilisation#
Pour des exemples d’utilisation on peut se référer aux cas-tests SSLS145 et SSLS146.
